22-10-2022 10:48 AM
I am trying to add esim by other networks. But i dont have that option (add data plan) in my iphone 13 pro under mobile data setting.
what is the problem by network?
22-10-2022 10:50 PM
Hello,
To add a mobile network plan simply navigate to the Settings app and tap 'Mobile Data' and from there you should be able to tap 'Add eSIM'. Alternatively you should be able to scan an eSIM QR code by opening the Camera app and pointing your iPhone at the QR Code.
I hope this helps.
Thanks and have a great day!
23-10-2022 01:26 PM
under mobile data i dont have any option for add data plan . This is my issue . I am using 13 pro.
23-10-2022 03:08 PM
Hi, have you tried scanning the plan's QR code using the camera. Thanks
