Battery warranty
busdennis
So my iPhone 11 is less tha 18 moths old with 8 months contract remaining. The phone is almost unusable due to the battery last only hours with minimal usage, every battery saving mode is switched on.
is the battery covered in any warranty and who should I be contacting? Thanks in advance
busdennis
Interestingly for future peeps wanting information the phone had a routine update and battery problem’s solved
busdennis
Only a few hours lol
Christopher_G
Hi @busdennis
I've found a really helpful Apple help page on battery life. Please have a look, it may help improve this a bit for you.
S4MUR441
You can check the battery health under settings -> battery -> battery health & charging. If the battery capacity is between 80% - 90% that's absolutely normal and it could indicate that there are some settings or apps that are draining your battery, i.e. a rouge app that's doing something in the background or Apple's frequent locations setting is on.
You can check the former in the same batter settings and the latter in settings -> privacy & security ->  location services -> system services.
Batteries are considered consumables and deteriorate over time. Usually, you can expect the battery capacity to drop around 10% each year.
If the battery is much less than that it may be faulty. Apple runs recall programs on a variety of parts/products so it's worth checking it as well.
The best starting point would be to contact Apple Support and see what they say.
busdennis
Leanne_T
Thanks for coming back and letting everyone know @busdennis
Leanne 🙂
