08-03-2022 08:46 PM
Hello,
I’m looking to upgrade with the anytime upgrade, can I trade in my phone if I have had my screen replaced privately?
thanks
08-03-2022 09:11 PM - edited 08-03-2022 09:12 PM
@S35ward provided everything works as it should. The device will be checked to make sure it’s ok. I highly recommend you don’t as it might not be up to scratch or water resistant if your device has an IP rating.
