18-11-2020 12:47 PM
Hi i have recently had trouble with my i phone 6 and lost 4g, i went on advice and tried various ideas that led for me to believe it was my sim card. unfortunately i put in my new sim card and it did not work either. could someone assist me further on what is the next step as i use the phone for work and cannot get 4g whilst on site.
18-11-2020 02:16 PM
Hi @Gavinvanson
Can you log into your My EE app, go to settings and make sure use data is turned on?
18-11-2020 01:28 PM
Hi @Gavinvanson
Have you registered the new SIM card?
Do you have any signal showing?
Thanks 🙂
18-11-2020 01:41 PM
Hi Leanne
i have registered the sim card and still the same and yes it shows the 4g at the top of the phone.
18-11-2020 01:46 PM
Hi @Gavinvanson
Thanks for coming back to me.
Could you let me know how 4G is not working for you?
What happens if you try and access any apps or Safari?
Thanks 🙂
18-11-2020 01:52 PM
Hi Leanne,
yes when i click on the app it says that safari cannot open gthe page because it could not establish a secure connection to the server
18-11-2020 02:03 PM
Thanks @Gavinvanson
Have you tried resetting the factory settings?
This will remove any saved WiFi passwords.
Let me know if this works for you.
18-11-2020 02:12 PM
18-11-2020 02:16 PM
Hi @Gavinvanson
18-11-2020 02:27 PM
Hi Leanne
thankyou very much as i am now up and running. never new that there was a mobile data in the app to turn on. thanks again
Gavin
18-11-2020 02:32 PM
