4G not working
Pjg19
Help! 4G has randomly stopped working on my iPhone 11, no idea why. Have tried all the usual things.
Leanne_T
Thanks @Pjg19
This indicates the SIM card may have developed a fault, to check this is the case and order a replacement please call us on 150 and the team will get this looked into for you.
Pjg19
Same thing has happened to me with iPhone 11!
Pjg19
Happens to me in multiple locations have tried turning it on and off etc
Leanne_T
Hi @Pjg19
Thanks for coming here.
If you go into Settings > Mobile Data > Mobile Data Options, do you have 4G showing in the voice and data option?
Can you make calls and send texts?
Is this affecting you accessing data?
Leanne 🙂
Yes 4G is showing. I can make calls. I tried it in another phone but that didn’t work either.
thanks!
phil
Leanne_T
Thanks @Pjg19
