30-08-2023 04:44 PM
My old samsung a70 IMEI number will not verify so cannot get an unlock code, can anyone help. I went into an EE shop and they said I had to phone EE. I did this and get an unlock code that didn't work. I haven't phoned them again as took 30 minutes for them to answer last time
30-08-2023 05:38 PM
Thanks for coming here.
What happens when you enter the unlocking code?
Are you using another network SIM card?
Leanne 🙂
01-09-2023 08:58 AM
Hi I put a sim in the phone, it then asks for the unlock code which I enter and it says its not recognised
01-09-2023 09:01 AM - edited 01-09-2023 09:01 AM
Are you manually typing it in, making sure there are no spaces at the beginning or end of the code, @stevejones7704?
01-09-2023 09:29 AM
yes no spaces
01-09-2023 09:43 AM
OK, thanks @stevejones7704
I suggest speaking to our Mobile Care team so they can look into this for you.
01-09-2023 11:15 AM
I did phone them and after waiting on the phone for over 30 minutes they did send me an unlock code but again this did not work
01-09-2023 11:24 AM
If you contact them to let them know it didn't work, they'll be able to help.
01-09-2023 02:04 PM
I haven't got time to hang around on the phone waiting for an answer
07-09-2023 03:52 PM
You can't actually enter the unlocking code as the process always sends you back to the beginning .
How did they get out of the groundhog day in the end as I feel I've moved there too.
