phone Keeps getting hot
niks35
I've got a Samsung  Galaxy S22 it keeps going really hot where is to hot to hold onto. It doesn't matter what I'm doing on it just gets really hot.
Has anyone else had this problem with the phone
@niks35  That’s the battery that’s getting hot.  Your device is working hard on something so is draining the battery causing it to get hot.   You could try a factory reset but it could just be you need a new battery.   You need the device to be looked at,  do not use it if possible as this is a fire risk.
