WiFi Calling Symbol
RJB1
Hello, my Samsung S24 ultra has just been updated to Android 15, since the upgrade the wifi calling symbol at the top of the screen is not showing. The wifi and wifi calling are both enabled, I've cleared the phone cache without success, all the info on the internet says contact my provider is the correct. Please can you give me any advice.
RJB1
Hello Rach,
A bit annoying, thank you for your reply.
RJB1.
Rach_H
Hi @RJB1,
Welcome back to the Community!
I'm sorry to hear you're not seeing this symbol. Are you able to test to see if WiFi Calling is working without the symbol being present?
Rach
Matt_124
It is seemingly working as intended, and not an issue with your phone or EE.
Since the update it seems as though Samsung have went for a "cleaner" look, but if you pull down the quick settings menu from the top right of the screen or your notifications you will see the missing WiFi Calling or VoLTE Symbol appear.
It continues to function as normal.
Northerner
Hi @RJB1
It doesn't show anymore as @Matt_124 says.
It is  UI 7.0 not Android which made the changes. Currently there is not any way of changing this setting which is annoying.
RJB1
Hello Rach,
RJB1.
RJB1
Hello Matt_124,
Thank you for your reply, I'll have a moan at Samsung.
Regards,
RJB1.
