Sony Xperia L4 not recognising SD card to save
m4x1ne
8 REPLIES 8
Is this a problem with one specific SD card? Does the same SD card work in another device - laptop? Tablet? PC?
Or do no SD cards work in your phone?
Thanks for response.  Tried 2 different SD cards, one brand new unused.  Both SD Cards work in laptop and can be accessed in Galaxy A6 Tablet.  Tech Guys at local shop couldn't work it out either so didn't charge me, after trying a few "fixes" but no idea what they tried exactly except reformatting the mobile itself, as well as transfering data on the SD Card and formatting that with different options.......
@m4x1ne   Does the device actually see the SD card/s when it’s inserted in the device.   Does it acknowledge the SD card has been put in the device?
Yes faulty card seen and it said it was corrupted.  2nd card recognised but not accepting images or data to be transferred even when trying to use the settings menu's, so I was told.  I'm not competent to check, but I could follow some instructions if required. Thanks for your help.
Northerner
Hi @m4x1ne
Have you formatted the card when its in the device.
Yes I kept doing that for about 1 month before taking it to the local repair shop for their advice.
James_B
EE Community Manager
Does the below Sony Support article help, @m4x1ne?
SD card not detected / not working | Sony UK
thanks, I'll have a go.
