27-05-2024 12:44 PM
Hi everyone,
Has anyone experienced sudden changes in battery life on the Sony WF-1000XM4 headphones? I've heard it's a widespread problem. Has anyone found a solution that works? Is EE addressing this issue?
27-05-2024 01:16 PM - edited 27-05-2024 01:16 PM
27-05-2024 02:41 PM
Since it was sold to me by EE, it's customary to address the issue first with the seller before contacting the manufacturer. Moreover, I have checked all the Sony forums, and the solutions provided there do not work for anyone. Also, I believe EE should address this because it's a widespread problem affecting one of its add-on devices...
27-05-2024 06:47 PM
@mar_c And how long have you had this product? As they get an 1 year warranty on the battery, And EE isn’t responsible for firmware updates for the product and the searching I’ve done online suggests that it was an update that might be the cause. And if it’s a wide spread issue then that suggests it’s a Sony manufacturing issue.
27-05-2024 08:59 PM
@mar_c Have you checked the Sony app for any firmware updates? Might also be worth a factory reset too.
