03-03-2024 07:38 PM
My new Galaxy A34 is showing emergency calls only and also the bars are flashing from 4 to no bars. I can't ring 150 as it says not registered on network.Help!
03-03-2024 07:54 PM
Has this phone worked since it was new? Your symptoms could easily read as either a local network outage or a fault with your phone - if it's worked since you first had it, that would rule the fault theory out. Restart the phone if you've not already, to rule out a glitch.
If it's a local network outage, you can use the "check status" option on https://coverage.ee.co.uk/coverage/ee
03-03-2024 08:06 PM
Yes it's worked fine since it was new. I've restarted but it's still doing it. I'll try the link you posted. Thank you
05-03-2024 09:33 AM
I woke up the next morning and phone was working normally with the usual two bars up. Must've righted itself overnight. Just a blip! After all that...thanks for your help!
05-03-2024 09:34 AM
Thanks for coming back and letting us know @Agnes7
