11-08-2025 07:14 PM
I have used the EE online unlock code generator and It returned a invalid code.
I have used 3 attempts on my Samsung S5 mini
And worried that I may lock it permanently.
The IMEI and unlock code has been checked 3 times. Any help would be appreciated thanks
14-08-2025 06:57 PM
Thanks for letting us know @EddieH.
If you give our team a call on 150 from an EE Device, or 0800 956 6000 from any other device. You can either select option 1 to use the visual service. Or select option 2, followed by option 1, option 1, option 1. This will connect you to one of our Mobile Guides, who will be able to help you with getting your handset unlocked.
Debbie
11-08-2025 07:18 PM
12-08-2025 08:31 AM
Hi there @EddieH
What is the exact message showing on the Samsung before you enter the unlock code? Are you using another network SIM when entering the unlock code you have been provided?
Speak soon 🙂
12-08-2025 01:50 PM
Have you tried entering the last 8 digits of the code, followed by the first 8 digits?
12-08-2025 02:49 PM
"SIM NETWORK UNLOCK PIN" and the code generator only gives eight numbers not 16 as described in other posts. Thanks
12-08-2025 02:57 PM
Just to confirm, the "EE online unlock code generator" you are using is this one?
https://ee.co.uk/plans-subscriptions/mobile/settings-permissions/device-unlock
13-08-2025 08:06 PM
Yes this is the generator I used.
I don't know how many attempts before It's locked forever but I used 3
14-08-2025 08:06 AM
HI @EddieH
It's best not to try any further. Please give Customer Service a call where a guide will be able to raise a ticket with our unlocking team to manually check and generate the unlocking code for you.
Ali
14-08-2025 06:16 PM
Hi Ali
I have called customer service but it seems to be automated I have followed various options but a I'm unable to talk to someone ,the best option i could get was to download the unlock tool but I guess it's the same as the online one. So how do I contact the unlocking team .?
Regards. Eddie
14-08-2025 06:57 PM
Debbie
