30-01-2024 06:19 PM
Samsung galaxy S21 won't get passed the loading up screen, does the same when reset. Can't get access to all phones images etc.
31-01-2024 08:06 AM
Hi @atewee
Can you try the steps in the Samsung phone frozen - how to soft reset or hard reboot page to see if this works for you?
Thanks 🙂
31-01-2024 08:29 AM
Hi Leanne,
Unfortunately I have done soft reset 20 times and not once has it got passed the Samsung logo. The phone wont tart in safe mode and I don't want to loose all of my photos etc by doing a factory reset.
31-01-2024 08:31 AM
31-01-2024 08:52 AM
I've tried it fully charged and with it plugged into the charger.
31-01-2024 09:06 AM
Thanks @atewee
The next step to try would be the factory reset to see if this works for you.
The Back up your Galaxy device if you cannot access it help page has details on backing up the data for you.
