27-06-2026 03:28 PM
My Ethernet connection from the EE router to my TV is fine but I have no signal from the EE router via Ethernet to my nvidia Shield consul.
why is this?
Do I need to get an engineer round or is the router blocking the connection?
27-06-2026 04:11 PM
Hi @JP1602
Which router.
Have you checked the cable is plugged in correctly. Have you given it a minute to connect.
27-06-2026 04:11 PM
@JP1602 Have you checked that all the Ethernet ports on the EE Hub are working fine by plugging the TV into each one at a time then seeing the TV operates on all off the ports, that would be the first thing to do!
