No WiFi calling option on S23 plus
Linziznil
I have a S23 plus and I don't get the best signal in my living room (all other rooms are fine, for some reason). I've looked at setting up the WiFi calling but it doesn't appear in my Connections settings. My device was ordered direct from EE. Can anyone help?
You're looking in network connections - try looking under phone/call settings instead.SCAR_Screenshot_265252019989006.jpg
Linziznil
I am also having the exact same issue. Did you manage to get this sorted?
chistery
Hi @Linziznil
Samsung hide it in the Phone app settings. You should see it there.
Linziznil
Thanks. I even searched 'wifi calling' and nothing came up.
