24-07-2025 07:46 PM
Why is ee not working today I've got no signal and can't make any calls out today Eva
24-07-2025 08:27 PM
@chantelle54 , it has been reported and other networks are also affected from what I have read, there is a major outage which EE are trying to rectify as a matter of urgency, although I did manage to make a call to a landline number this evening.
25-07-2025 08:32 AM
A lack of coverage is not a symptoms of yesterday's calling issues, you may have a different problem.
If you've not done so already, try toggling flight mode to ensure your phone hasn't "dropped off" available coverage.
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker in the first instance, to check for local service outages. The "report a problem" link should be used if no issues are reported but EE users continue to have issues.A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
