03-11-2022 09:11 PM
04-11-2022 09:08 AM
Hi @JuliaSays.
Welcome to the community.
Do you notice if this happens in more than one location? Is it every call that is affected?
04-11-2022 10:22 AM
Thank you for getting back to me. It is every call, whether using the phone or trying to call through WhatsApp. But the mic itself is working fine, as diagnostic tests have passed and I can record voicenotes in WhatsApp. I have tried everything, including reset to factory settings last night but it just won't work.
04-11-2022 10:49 AM
That's really strange, especially since it's happening after a full reset, @JuliaSays.
Could you try the SIM in a different phone do you think? Or a different SIM in yours, just as a test?
04-11-2022 11:00 AM
Unfortunately neither of those are available to me today. Perhaps if I pop into my nearest EE store this afternoon they might be able to look at it for me?
04-11-2022 11:30 AM
Yes, they should be able to test a SIM swap for you, @JuliaSays. This should help narrow down what is causing the problem.
05-11-2022 08:02 PM
Calls placed through WhatsApp and other apps, are not handled by your phone or EE's mobile network as calls - but as data usage. All that helps prove is your microphone and the phone's data connection.
Does your phone have an option for forcing a 3G/2G network connection instead of defaulting to the 4G network - ordinarily this is a bad idea, but for troubleshooting purposes it may help ID if this is part of the issue.
