on 20-03-2026 06:36 PM
Hi Everyone,
I'm on Android and was forced to use 5G when I joined up with EE last week. On other phones the *#*#4636#*#* worked, but on my Honor M8 Pro it doesn't. But this does work, put your phone on POWER SAVING mode, it only means if your battery goes below 20% it will kick in, but it FORCES 4G! Problem solved, try it! 🙂👌🏻
Solved! Go to Solution.
on 20-03-2026 10:48 PM
You only need to reply once, you can edit posts if necessary.
5G phones will use 4G as a matter of course, anywhere that there's no 5G coverage. When in NSA mode, a 5G phone will also use 4G for calls by design.
You don't need a phone setting for this to work.
on 20-03-2026 07:54 PM
Hi @OldL
Why would you not want to use 5G.
Is there no settings under connection.
on 20-03-2026 08:00 PM
I should've mentioned were not in a 5G area so we need 4G.
on 20-03-2026 08:05 PM
We don't have 5G in our area so we need 4G. No there's no option under settings to disable 5G or change it to 4G.
