14-05-2025 05:36 PM
My battery has lately been terrible and also the phone will freeze every time. Right now I am typing this message on my iPad. My pixel 8 pro has refused to power ON. I have tried to hard reset three times this week. My contract still runs to December 2025. What should I do?
14-05-2025 07:00 PM
Hi @Willsofg
Check your warranty on Google:
https://support.google.com/store/answer/6160400?hl=en-GB
Alternatively contact EE repairs and they will tell you if the issue is covered by your warranty.
https://ee.co.uk/local-repairs
I would back up first and try factory resetting your device to see if that helps.
14-05-2025 05:44 PM
Devices freezing can often be a sign of memory running low and/or too many apps running simultaneously. A bit of regular housekeeping can go a long way.
For refusing to power-on, assuming it's connected to the mains... https://ee.co.uk/local-repairs is as good as anywhere to start
14-05-2025 07:00 PM
Hi @Willsofg
