Broken screen so can't transfer info
SamAdd
The screen on my phone broke.  I am using my sim in another phone but as the screen is inaccessible I can't use smartswitch or any other method to transfer my data and info.  Any ideas?  Thanks.
You may be able to use Smart Switch connected to a laptop, without needing an onscreen confirmation.
If not, then you probably need to consider the data lost. It may be worth considering a rolling backup schedule to always have something to fall back on.
