Broken phone data transfer
Stephanie331
I have an S10+ which I dropped and have broken the screen. The cost was too high to have it repaired so decided to take out a contract on a new Samsung device. I have been unable to do the data transfer with a cable as I'm not able to see the whole screen on my old device.
Does anybody have any ideas how this can be done?
Tia
@Stephanie331   Without screen interaction on the device the best you can do is plug into a PC back up your old device and then transfer it to the new device.   You’ll not know what been saved until you open the new device.
