25-06-2020 09:35 PM
Hi, i a planning in buying a 4GEE wifi hub for my personal use (xbox one mainly) , before i buy, how would i connect the hub to my xbox? Do i need a laptop of some sort? I would be buying the 50gb plan also, is the hub any different from using hotspot from my iphone at all? Can someone please explain the process of it from hub arriving to actually connecting and using it for gaming pls
25-06-2020 10:13 PM
Hi @RyanNapper and welcome to the community.
The 4GEE WiFi emits a WiFi signal that you would connect to from your Xbox like you would connect to a phone hotspot.
Basically pop the SIM in, switch it on, go into Xbox WiFi list and connect.
Peter
25-06-2020 10:13 PM
Peter
26-06-2020 12:13 AM
Posted in the open:
@Napper123 wrote:
Hi, i am fairly new to this and i see youre a veteran in alla this😭im looking to get the 4GEE WIFI HUB to mainly use for gaming. Just casual xbox after work or on days of
anyways, im looking to find out, how you set up, connect and use the hub with my iphone X/xbox one, do i need a laptop of some sort? Can you please describe to the best you can the process, i am not getting broadband due to my house being large with housemates so its something personal i just use. Id really appreciate if you could help
26-06-2020 12:15 AM
@Napper123 : You just connect your devices by WiFi just like you would with a BB router.
