tv remote / voice command
ellandroad
I have just set up my ee tv box pro but it will not pair my tv remote unless i put it setbox settings - why is this ?
I was told the remote control had voice command on it but i cannot find it or use it
Yes, that is correct.  The TV Box Pro and TV Box Edge do not support voice control.  We do offer Apple TV, which supports voice, if this would be more convenient for you.  You would lose the ability to record programmes though.
10 REPLIES 10
Rach_H
Hi @ellandroad,
Welcome to the Community!
I'd recommend reaching out to our team to query things, if your plan isn't what you had discussed.
Rach
@ellandroad  It doesn’t have voice control not sure why you got told it has.
Hi Chris, cheers for that BUT what does bluetooth voice command mean then
Where are you seeing reference to "Bluetooth voice command"?
Hi Rach,
Plan is fine its just the bluetooth voice command i dont understand or why tv remote only works with setbox on and not tv
I am seeing in little ee book bluetooth to control your tv box
Yes - the EE TV remote uses Bluetooth to communicate with your TV Box.  There is no voice control though.
Cheers Darren for that but does that mean i have to manually input any search i do now instead of the voice command i use to have on my nowtv remote
