TV pro box Netflix app problem
Gary2paws
Problem with my EE TV pro box Netflix app.
This app keeps kicking me off Netflix after approx 4 minutes of watching on Netflix. This as been happening since end of March and after several reboots of both hub and TV pro box and a new box sent to me. This problem is still happening.
Now I have been told that it's a Netflix update problem and they are trying to fix it. A call to Netflix and I was told they have no record of an update problem therefore, who is telling me the truth? Does anyone else have this problem?
36 REPLIES 36
Hiya, having the same problem. Could you add me to the list as well please. Thank you
DarrenDev
EE Product Expert
Thanks @Sunflowerbee - I've added you.
There are a couple of things that you all have in common, which I think will really help narrow down the investigation!
Hi. Yes happening to me also. Netflix kicks us out after about 4mins. Thanks
I've added you to the list @JayBee74 however I can see that there's a fault on your line causing extremely poor connection speeds - it's running at much lower speed than it should, and frequently switching to 4G backup.  I recommend you call to raise a fault, as the system is showing a high resistance joint. It should be easy to fix.
Mine working fine properly people have very slow Internet issues as being wacthing Netflix without no issues today on my Mini Box looks the issue has being fixed
HughHodge1
Hi. Just tried Netflix again and it all seems to be ok now. Only thing I did was reboot of the router yesterday and today Netflix seems to be ok.
Well I have just tried mine and I'm unable to watch Netflix for long. Hearing about reboot I decided to reboot my broadband box and then I re set my TV box to factory settings and started it again. But still having issues.
Obviously your fault is not the same as mine.
Looks like another month without Netflix.
