TV Guide wrong for Sky channels
lufc87
Over the last couple of days I've noticed the TV Guide is incorrect for some Sky channels. For example, the guide currently shows Game of Thrones for Sky Atlantic but what's actually on, and correctly shown on the Now TV app, is The Guilded Age.
The Movie channels are all over the place. As an example, the guide currently shows In the Line of Fire on Sky Thriller but Zulu is actually on. Sky comedy shows Dumb and Dumber To but it's actually Dad's Army! I don't think any movie channel is accurate.
I've reset my box but no change.
Richardr66
Expert Contributor
Expert Contributor
Sky had technical issues yesterday with SkyQ which among other things affected PIN entry. Movies and series such as Game of Thrones can be shown before the watershed as long as a PIN is input. They removed such movies and programmes from their pre-watershed schedule as a result. From what you say it looks like the same has happened today.
Richardr66
Expert Contributor
Expert Contributor
lufc87
Ah ok, guess the guide doesn't sync that frequently to EE
DarrenDev
EE Product Expert
There is an additional fault at the data being supplied to us for many channels is incorrect - you'll see many other discussions on these forums about recordings, schedules, and series links.  The issues with Sky channels over the last 48 hours just made matters worse.
