TNT
HeatherB52
HI everyone I need help I have heard TNT is moving from discovery to HBO Max will my add on for TNT move from discovery to HBO max ?
scousegeek
Yes you will be able to access TNT sports through the HBO Max app. Further details will be sent to customers closer to the launch date according to the help article https://ee.co.uk/help/tv-sport/hbo-max.
Hope this helps for now.
scousegeek
That only mentions ee TV and broadband nothing about add ons through ee mobile which you can access on smart ti's, firesticks etc. Obviously we want to keep our £20 per month add on.
zulu17
Star Contributor
Star Contributor
It would be helpful if EE indicated when their help article is updated and what additional information has been included as that article has changed since it was first published last week !
....i don't see the reference  that that Scousegeek mentions to further information being sent to customers mentioned in that help article  currently but as I say I have noticed that the content appears to change (probably for the better to add  information/correct accuracy) but as it describes itself as "Here’s everything you need to know. "  that implies it should be complete -- if it is work in progress then perhaps phrasing it as "Here's what we know so far - check back later for further details".
Rach_H
Hi @SackBoris,
I can see that the help page has been updated to show how this will impact your mobile plan.
Rach
