TNT Sports move to HBO Max with TV purchase subscription
William765
Since TNT moved from discovery + to HBO max my TNT has not worked just says get access as bought a tv Samsung 1 year ago with EE and got 2 years free sports on discovery + on TNT since this move and my sports has not worked and is still active on EE as have checked its active anyone had this problem have tried everything taking app off putting back on same thing happens please help mr obrien
DarrenDev
EE Product Expert
Can you please double check that you're logging into HBO Max with the same email address you used for discovery+?  This is the number one cause of failure.
When you say you checked that it's active on EE, how did you do that?
DarrenDev
EE Product Expert
William765
Yes thanks for your help put wrong email in put in correct one in working a treat mr o brien
