Parental controls on TV
Shell_
 I have recently had the TV installed and am unable to turn off the pin requirements.
 Ive gone to home, settings, restrict and turned everything off. However i'm watching Gavin & stacey and its asking for a pin every time the adverts finish.
 Any advice?
zulu17
Problem solver
Problem solver
I presume as you mention adverts this is not on the BBC so presumably  you are watching the reruns on Now U & Gold during the day or early evening. So you are probably  experiencing the broadcaster using mandatory  daytime PINs to adhere to Ofcom guidelines .. Some of the GAVIN & Stacey episodes have a 15 rating so broadcaster  is using the mandatory PI N  to allow the programme  to be broadcast unedited  pre watershed. Not sure why they would apply it after each advert break  if the same episode (programme) continues.
DarrenDev
EE Product Expert
Which app are you watching Gavin and Stacey in?
Shell_
Just live tv
zulu17
Problem solver
Problem solver
Shell_
 Thank you very much, so no way to turn it off 😟 it's a pain it's so frequently must be an error somewhere
