27-11-2026 02:18 PM
I’ve just moved to EE tv and broadband. Had texts to say it’s all set up, but when setting up my TV all the channels from my NOW subscriptions are not working.
I receive a message that “you need to check your access” but when I click OK it says it can’t activate at the moment and try again later.
this has been going on for hours
27-11-2026 02:31 PM
Unfortunately there is a fault meaning some accounts are taking longer to process - sometimes hours, or sometimes they're requiring manual intervention from a team who is picking up failures and contacting customers to sort it, which can take a few days.
I can fix this for you straight away. Simply email [email protected] with your account number, and the email address you'd like your NOW subscription to use. If you have previously used that email address for a NOW account (even if it doesn't have a subscription on it anymore) then mention that in the email and it'll speed the process up a bit.
27-11-2026 02:31 PM
27-11-2026 03:01 PM
Thanks Darren. I have sent an email.
