11-02-2024 05:40 PM
I’ve been watching the various posts on here about the can we / can’t we transfer from BT to New EE. I was interested in getting the Apple TV and New Hub as well as the mobile benefits.
I noticed last week that all the problems should have been resolved and we should be able to order, so promptly rang. I got all the way through ordering with one person who then couldn’t go any further because the system wouldn’t offer me Hybrid Connect (we already have it) and he said he would ring me back at 1300 today (no call). So I’ve just rung again this evening and apparently the TV option isn’t possible again and I’m booked in for another call back on the 16th.
Seriously EE/BT, this is just ridiculous now. It’s a half baked launch and a complete waste of customers time. If it’s that difficult to sort your systems out, you have probably made them far too complicated. When it comes to renewal, you’ve just given me a reason to rethink. Has anyone who is/was with BT managed to successfully transfer to New EE?
22-02-2024 09:59 AM
That will explain why I haven’t had a call back yet then. When I was last on the phone to them, it wasn’t even coming up as an option to order.
22-02-2024 01:27 PM
Finally found someone with answers.
1.6Gbps orders go via a different system that isn't currently capable of including TV orders - so it's not possible to order EE TV on a 1.6Gbps line. It's likely to be at least a couple of months before this changes.
We're not aware of any reason why Hybrid cannot be included with an EE TV order though - as long as you're not ordering 1.6Gbps. Could someone who has tried this please email me at tv.apps@ee.co.uk with your account number, and I'll try to trace through why it was rejected.
29-02-2024 07:41 PM
I’ve just upgraded and got the new Apple TV 4K box.
However it’s all gone wrong on the Broadband side. No Hybrid Connect. And that just as we were finishing he dropped in no new router either. He tried claiming there was no difference between the new router and the BT Smart Hub 2.
I’m told that once it’s all active I can then ring up and get the new router and Hybrid Connect. Why is this so difficult?
01-03-2024 01:34 AM
@LivinThing not entirely sure, if they dropped the supply of EE Smart Hub (not plus) which was EE choice for lower BB tiers, and only for FF900 and 1.6 Gbps package was supplied new EE Smart Hub Plus (SH31B)...
If You have, say 500 Mbps tier, and they still aim to supply a non-plus version of EE hub, then YES, that router is essentially SAME as BT SH2, just in a different enclosure (and perhaps WiFi 5 only)... This is little bit a funny, because BT SH2 is hardly capable to deal even with FF500, not alone with FF900 🙂
01-03-2024 01:37 AM
That's little sad @DarrenDev whilst:
- I was told back in December, as it will be available no later than with new year - obviously not happened
- I was told last week, that it will be available in March, and I should call them then... And You now mention a couple of months...
My 1.6 Gbps package is running nicely, and I am happy about that, but all that chaos and not readiness around? Little rushed than, especially when Guides itself, apart Belfast "next Gen" people aren't even able to provide any reliable info...
01-03-2024 07:41 AM
I wish we had a FTTH product, alas max we can get is 35mb. that’s why the Hybrid Connect is so valuable, the line does drop regularly.
I was more concerned that the operator was adamant that the EE Smart Hub Plus was exactly the same internally as the BT Smart Hub 2. I explained that EE SHP was Wifi6 and the BT SHT was 5. Even recommended he google it.
So now I’ve moved over to new EE, but I’m paying the same as before and potentially getting less features. I’m not convinced this is going to work.
Feels like I’ve been sold magic beans!
01-03-2024 11:39 AM
@LivinThing at your line speed, you're not going to see any benefit from the new router anyway? My understanding is that they'll only send you an EE SH2 - i.e. the same as what you have, but with the EE branded case.
I can see on your call notes that there was a system fault that prevented the Hybrid Connect order. I'll try to find out why, but I can see that they've recommended you call back after your order fully completes on March 5th.
01-03-2024 12:02 PM
WiFi 6 is definitely beneficial in a house full of WiFi 6 compatible devices, even if it doesn’t make much if any difference to the broadband speeds.
02-03-2024 12:33 AM
@LivinThing You are right, in terms, of WiFi 6 could be an advantage over WiFi 5, even Broadband end (WAN) isn't such speed, especially, if You have heavy traffic INSIDE Your LAN, between devices connected to it.
BUT, if You have very heavy traffic inside the network, it's more beneficial to hard wire as many as possible devices, and take control over the flow of traffic, for example, if You have 2 NAS storages, and Your PCs use them a lot, it's better have them on Wire, where possible, not on WiFi, and have set rules for traffic, to not bother WiFi part, as much as possible...
Obviously, an advantage of the new EE Smart Hub Plus (2023) is also availability of 160 Mhz channels, as well as DFS portion of WiFi 5GHz-II and 5GHz-III bands, which, paired with compatible devices could benefit You greatly.
Sadly, if You are not on Full fibre (FTTC or FTTP) there is at present really not supplied new SH31B router, just "rebranded" BT SH2, and therefore, there is no need to upgrade it, from EE point of View.
You always could ask them, if this will be possible, but I guessing, the answer will be no. As long as they operate SH2 (or EE rebrand of it), and giving it away to new customers, they will not really be willing to make exceptions, especially on suchlower package.
At present, the only viable option is a third-party router, but that might be limited, in terms of your exact product.
02-03-2024 12:57 AM
@LivinThing have a look at the product marketing for the product you moved to. As an example I moved from BT halo3 to EE fullworks76, (so like for like) All my kit was replaced with the EE equivalents the wifi 6 definitely helps (but the firmwares a little flakey). My original Bt account was closed (and got the return request for the BT Kit). If your within the 14 day period you can always go back to the original product and if you paying more for the new product and not getting the benefit I'd definitely consider it. Just be warned I have seen posts from people who had issue going back to the old product (even in the cooling off period)
Just my opinion but the whole new EE broadband launch has been a joke especially for anyone they are pushing to migrate, and if you ring and have an account problem make sure you mention its NEW EE broadband, the teams still seem to be fragmented and the phone system routes you to guides who aren't yet able to help and you'll have to be transferred.
I will say though when it works it is good, just a shame poor backend systems & implementation have let it all down.
