How can I turn off the blue light on the front of the EE TV box pro?
AcornBob
Northerner
Hi @AcornBob
I don't think you can becase it's an important indicator light. Might need to use tape if it is annoying.
Northerner
Hi @AcornBob
Thank you Northerner,
I just find it quite distracting sitting under the telly. perhaps I'll find some black tape.
Oh Well!
The remote control uses Bluetooth so you could put your TV box somewhere out of sight - just bear in mind that it may affect WiFi signal, if that's how you're connected.
AcornBob
Thanks DarrenDev,
I’m about to build a TV stand and I will design it so that I can hide the EE box, I’ll use a power line extender to get the signal into it.
