Error yvm305
Lisamw7
Hello,
I have error code yvm305 with no tv channels at all my tv box pro is only letting me set up using an ariel, I don't have a tv ariel but it won't let me select the option to stream tv I have tried factory setting but still no option, please help
Peter_W
Good morning @Lisamw7.
Thanks for reaching out to us here on the Community 😊
When you first set up your box, it will ask you to select either aerial or IP mode, and this error would suggest you're in aerial mode but understandably can't pick anything up.
It is possible to switch this but you'll just need to do a factory reset on the box.
If you give this a try and make sure to select the option for streaming TV over the internet at setup, you should be all good to go.
Peter
Peter_W
Peter
