Ee tv mini box vs pro
killie97
Do I need to get a Pro box before I can access the Freeview channels I had under BT TV ? When I moved from BT to EE I got a mini box but can't get access to all channels as there is no way to connect aerial to the mini box.
Weerab2024
Problem solver
Problem solver
@killie97 yes if you want all the Freeview channels that EE don't offer on their IP channel listing, you need the Pro box.
The only channels that you currently get in IP mode are https://ee.co.uk/help/tv-sport/manage-use/channel-guide
Only one Pro box per customer though.
Otherwise you would need to switch between your Freeview built into your TV for the channels that aren't included
EE Pro TV box, Full Fibre 900
For EE contact details see
https://ee.co.uk/help/contact-ee
Weerab2024
Problem solver
Problem solver
