EE tv on apple tv subtitles
Markd53
I have recently been getting problems with subtitles coming on by themselves, i am having to keep turning them off as im not asking for them to come on.
is anyone else having the same problem on there apple tv EE tv is there a fix for this.
Hi
Turn off auto subtitles in the Apple TV settings.
10 REPLIES 10
Midnight_Voice
@Markd53
Apart from the On/Off toggle you get when watching a programme, there are subtitles controls in the Apple Settings app. Have you checked these out?
Ye tried all that, i wonder if it maybe because i turned off allow app to track feature maybe that doesnt remember your last settings.
whats the thoughts
@Markd53
I can see where that might stop the subtitles appearing the same way on another device, but not on the same one.
However, if you think it might be that, try allowing tracking for a bit, and see if that cures it.
SharonBurns
Same problem here have you managed to solve it?
Yes it was the option in your Apple TV where you allow apps to track switch it on to track and it saves the settings
Profile closed
Not applicable
Also having this issue. Where can I find the setting to change it?
Profile closed
Not applicable
Turned on app tracking but still having this issue
Hi
Leanne_T
Thanks for sharing what resolved this for you @Markd53
Leanne 🙂
