16-03-2026 05:37 PM
How do I replace my bt tv box with ee tv box, been with ee a while and box playse up and freezes, check everything suggested.
16-03-2026 05:40 PM
No need! They are the same.
16-03-2026 05:51 PM
If it's a TV Box Pro then the EE one is exactly the same - just in a different shape case.
If you have an older Humax box then you can upgrade to the TV Box Pro by giving us a call - as long as you still have an active subscription then you'll be entitled to it.
