EE TV add a second Apple TV box?
daweller24
Is it possible to add a second Apple TV box or simply a case of buying one and logging in on second box?
Vichu1
EE Product Expert
It may not be possible but best to ring the agents who can suggest the best deals/options you can get.
Weerab2024
Problem solver
Problem solver
You can only have one official EE Apple TV box.
You can have upto 2 mini boxes from EE for multiroom (first one is free as far as I am aware)
If you want a second apple TV box you would need to buy one but it will be the one direct from apple and the EE TV guide app won't be able to be used on it.
You can use the on demand apps though to get most of the free content and channels that you can stream directly from most of the main catch up apps.
EE Pro TV box, Full Fibre 900
For EE contact details see
https://ee.co.uk/help/contact-ee
