EE TV Box buffering/freezing
CBoasty
we just signed up to the EE TV full works package and even had an engineer come out last Friday to check our connection and setup. He checked it and we get 150mbps download speed and he said it should be more than enough to get good tv through the wifi.
since he left all we’ve had is all of the apps freeze, tv pretty much unwatchable through the EE TV box. We switch to our smart tv and can watch now tv, Netflix etc with no problems whatsoever… but through the EE Boxes cannot watch anything without the picture breaking up and freezing. This happens to both the pro box and mini box. I have done resets, reset the internet multiple times and this does not help. I even have a wifi extender/repeater setup to see if that mitigates the problem with no success. I have read plenty of posts experiencing similar. It’s frustrating as we just left sky q and didn’t have any issues and we are already debating going back to sky as we are within the cooling off period. Is there any advice on what we can do? Or anyone experiencing similar? Is it the boxes?
55 REPLIES 55
rdc384
Valued Contributor
Valued Contributor
I only have the mini box so no recording
Same problem here. Did the power extender fix work? I have a couple of old ones left over from Talktalk days. Was hoping I wouldn't need to use them again. Ethernet connection not realistic - who has their TVs in the same room as their router?
tvted
Has anyone yet come up with a definitive answer/solution to EE Pro TV box picture freezing and breaking up?
No it did not work, but after spending hours on the phone to EE they eventually sent an engineer who plugged his laptop into the router did some update and it works perfectly now…
I too have had problems with EE tv. The tv screen freezes and pixelates often which spoils my viewing experience. I have rung up for technical help and have had checks done each time which say everything is OK. I have been often told that it's my television set yet I am on my 3rd one in as many months but the problems still exist. I was told to try a direct cable feed from my router to the tv box, so I had an engineer install 2 new network cables plus a new tv aerial cable but the problems still exist. I complained again to EE and managed to get a replacement EE tv box but the problems happened again just after plugging the new box in. I tried it using wifi and the direct feed. I have turned off, rebooted and reset many times but still the problem occurs. I will change my broadband supplier from yourselves as soon as I can. I hope this now makes you aware of the problem?
rdc384
Valued Contributor
Valued Contributor
Thanks, I hope yours is sorted. Mine went away, maybe an update
Regards, Richard
