EE TV Box Problem
N_i_c_k
Can anyone understand why my EE TV box has to have a full hard reset every time I turn the TV on? (Pressing the button for X amount of seconds on the box).
I get error code YVM104 - Which is internet related. I've swapped out the CAT5 cable and tested my internet speed 600+Mbps... The internet isn't the problem. The box is hardwired to the router.
I just want to watch TV and it's a pain having to do this every time
Thank you for any advice!
N_i_c_k
Solution!
Connected via WIFI and never had an issue since.
Thank you all for helping
6 REPLIES 6
Northerner
Hi @N_i_c_k
Which router do you own as it maybe your router port is sleeping or in some cases there is a delay before the ethernet port activates.
Try over WiFi to see if you get the same issue.
DarrenDev
EE Product Expert
Try disconnecting the ethernet cable for a moment instead of rebooting - it should fix it quicker.
I believe there's a known issue that devices can fail to connect immediately after waking up, although I thought it was supposed to recover itself after 30 seconds.
Hello,
It's the Smart hub SH32B
Good idea with the wireless connection, I shall try that and report back,
Thanks for your help
Juley133
I'm having to do the same ,loosing tv ,have test line and say internet issues, have to do unplug router and reset, this is a pain have reported it but had no response ese
Christopher_G
Hi @Juley133
Welcome to the community.
Did you see @DarrenDev's reply above? If you're using an ethernet cable too, that may be a quicker way to restore connection. You've done the right thing in reporting it, hopefully there's a fix in place soon.
N_i_c_k
Solution!
