Do subscribed EE TV packages function in holiday home?
Bob541
Is it possible, via an EE Mini Box , to view the same EE subscribed TV channels/packages that you have in your main residence at a holiday home in the same country?
I'm led to believe that if you have EE broadband at your holiday home that it can be achieved.
1 ACCEPTED SOLUTION
DarrenDev
EE Product Expert
The TV Box Mini will automatically take on the subscription of the line that it's connected to, so if the EE Broadband line at the holiday home has an EE TV subscription then it'll work. I'm assuming it doesn't though, so the box will lose access to channels and the EE TV app.  Other apps will work fine.
Matt_124
I don't believe so, as the live channels in the TV Guide are fed through your specific line.
You can however use the respective apps on that same box to access your subscription channels, such as iPlayer, ITVX, Discovery+, NowTV etc, depending on which package you are on.
Apps will work with any internet connection, your regular TV Guide channels will not.
DarrenDev
EE Product Expert
