on 05-12-2024 02:39 PM
I am already experiencing problems with sound on Discovery plus when I lose sound after an ad break which I have discussed here.
I also have a problem watching Discovery plus (Smallest Cog, and Vinny Jones on catch up) in the evenings. Whilst watching these shows we get a message flash up saying 'broadband disconnected'. About 15 seconds later the programme freezes for a short while, then we get a message 'broadband reconnected' and the show continues. My connection to the EE box is wired so I can't see how we lose any signal.
Anyone else experiencing BB dropping out on Discovery plus?
on 05-12-2024 02:47 PM
Which EE BB plan are you on including its speed? What EE router do you have (read its label or post a pix)?
BB disconnected means the connection to the BB network has gone down.
on 05-12-2024 09:52 PM
I have essentials full fibre gigabit with wifi 7 router. Apparently all singing all dancing best you can get.
Been with EE a month.
on 18-05-2025 01:01 PM
i am paying £8.99 for the disney+ add on and have found that i have a direct acct costing me more so how do i remove and get refund for the charges made for this.
on 18-05-2025 03:35 PM
Hi @Jenn1967
Thanks for coming to our community.
To make changes to your account, please get in touch with our customer care team who can help with this.
Lesley
on 20-10-2025 09:08 PM
Well here I am again.
There is a new series of the Smallest Cog on Discovery plus and it keeps losing broadband for 15 seconds.
I've googled it and found my original post about this problem (which I can forgotten about)!
Is it the smallest cog causing the problem?
on 21-10-2025 11:16 AM
Hi @OldJohn.
Thanks for coming back to us.
I'm sorry to hear you're losing connection when watching the Smallest Cog on Discovery.
Could you try restarting your streaming device and your router, then check for any app/system updates. It's also worth clearing the app's cache to see if this helps.
Let us know how you get on.
Debbie
on 17-11-2025 08:45 PM
I've done that and last week it dropped out 3/4 times, this week didn't lose connection.
I'm confused how the EE box loses broadband connection when it is a wired connection!
on 18-11-2025 10:21 AM
I'm pleased you haven't had a connection loss this week @OldJohn
Hopefully it is resolved. If not, it might be worth looking at the cable itself if its a wired connection and still dropping, just to rule that out.
Lesley
on 24-11-2025 07:59 PM
I appreciate your comments, but I can't believe a cabled connection will only fail when Discovery plus is on. The problem is clearly a technical issue, not a physical wiring fault.
Let's draw a line under this, thanks.
