Can’t access Paramount TV any ideas please
srowell
zulu17
Star Contributor
Star Contributor
On the Box Pro the Paramount + App does I believe allow you to sign in on your Tv but also On the Web by visiting  paramountplus.com/tv   and inputing the code displayed on you TV screen. (A scanable QR code is also availabe on the screen)..
The EE guidelines are at
https://ee.co.uk/help/tv-sport/manage-use/paramount-plus-on-ee-tv
Michael_D
Hi @srowell
Welcome to the community.
What is happening when you try to access Paramount?
Is it the app on the EE TV box?
Do you have a Paramount subscription set up?
Michael
Hi
I have a subscription through EE it was part of the sign up deal. Asks
Me to log in then won’t accept my password so I’m trying to reset the password but it won’t let me use it on my TV I can log in fine on my phone.
Sent from Outlook for iOS<>
Peter_W
Thanks for confirming that for us, @srowell.
Has this worked for you in the past?
Also what exactly is happening when you're trying to reset the password?
Peter
zulu17
Star Contributor
Star Contributor
