26-04-2026 01:47 PM
Hi!, For the past good few months i have been paying Netflix directly £5.99 for the basic plan with ads, i can see now, as i have EE TV (TNT Sport and the Entertainment plan), that perhaps i should have been able to get the same package for free with EE through the Entertainment plan subscription for Now TV, (unless i have misread something), anyone have any ideas if this is correct and if it is, what i should do next? Many Thanks.
26-04-2026 01:57 PM
It's included with the EE TV Entertainment package, however you have the Sport package with the Entertainment add-on. It's not included with that combination.
26-04-2026 01:57 PM
26-04-2026 02:03 PM
Okay, no problem, thanks for the quick reply Darren.
07-09-2026 10:31 AM
I have the same and pay£18.99 for my own Netflix account. Is tgere a cheaper way of doing it via REEE?
07-09-2026 11:24 AM
@SimonK99 you're also on a Sport subscription, which doesn't include Netflix. You can move it onto your EE TV bill if you'd like, but it'd still cost the same.
