App rail
Tomjeffrey20
If i click apps all the apps ate there but now a lot are missing on the home page after a update
DarrenDev
EE Product Expert
Not all the apps are shown on the home page.  The apps rail was made smaller so that more could fit on it, but there's not room for them all.
zulu17
Star Contributor
Star Contributor
I think on the home page
At the top  there are six prominent apps (the four PSBs  - iPlayer,,ITV X, Channel 4, Five)  and two other selected featured popular apps that may  change over time. As you navigate thru those apps a  suggested programme is promoted..
(I dion't know if there are variations for Scotland,Wales, Northern Ireland)
The app rail further down the home page I think is including  the remaining apps (ie excluding the six described above)  in the (YouView ranked)  order of prominence..The apps rail is smaller so more fit on the screen but with scrolling to the right you should seem all the remaining apps including the Help app at the end.
If you were to select Apps on the left hand side menu of the home page you will still get the box grid arrangement of all the apps together in the YouView ranked order of prominence.
