29-03-2024 08:59 PM
I have seen there are issues for anyone making the move from BT to EE and after several calls I learned a few things that may help - although there's still things to resolve:
Anyway, along the way I learned a few things...
I hope these hints will help - even if you need to call and do the accounts on the phone with the call centre setting it up with an invite ID link.
Its a pain, but the only way I could access the Wifi/EETV/Plans stuff.
29-03-2024 09:07 PM
Also, why cant I use more than 1 Device in the EETV app with a Full Works subscription?
Having to wait a month to add a second device, and then up to 4 months to add 4 devices seems a bit, well, dumb...
31-03-2024 09:11 PM
@Corky-100 with a new account, you can register 4 devices straight away. When those 4 device slots are full, you can then make 1 change a month. This is pretty standard with video content, to prevent accounts being shared.
Regarding this other point:
You simply need to press Home+9 together to reset the remote. No need for a keyboard.
31-03-2024 09:47 PM
I can only use 1 device strangely, says I reached my limit... although I suspect the account is still only half cooked - Can't add the Discovery Premium to my Discovery app either.
For the remote, I needed a new one as despite Home+9 or Home+7 it refused to work again, except for power button. I've seen this as a common issue.
Thanks for confirming I should have 4 devices though.
31-03-2024 10:07 PM
You say you moved from BT to EE, so I assume you had devices registered on your TV account before the move? As it's an account move, rather than a new account, your existing devices would have been carried across. Feel free to email me at [email protected] with your account number, and I can check/reset as needed.
