Why is my voicemail not working?
EmmaHan
My voicemail seems to be set up with a bespoke greeting although calls just ring out & are not directed to voicrmail. I use the phone for business use so it's upsetting my clients that they can't leave me a voicemail.
Alex_M
Star Contributor
Star Contributor
Hi @EmmaHan,
If you text VM ON to 150, does it say that it has been activated successfully?
Could you try your VM now that you have sent the activation request?
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
6 REPLIES 6
Alex_M
Star Contributor
Star Contributor
Hi @EmmaHan,
Thanks,
Alex
Yes it does now, but why did it stop working in the first place?
Alex_M
Star Contributor
Star Contributor
Hi @EmmaHan,
Glad it is fixed now.
I am not sure why it would have turned off - maybe just a glitch!
Thanks,
Alex
Must have been. Thanks for your help!
MelPeck
I'm having the same issue and when I text VM On to 150 I get the following message:
Sorry, we're having some trouble completing your request at the moment. Please try again later.
It keeps doing this so I can't turn it on. Can anyone help please?
Many thanks 😊
Katie_J
Hi @MelPeck.
I am sorry to hear you are getting an error message when trying to activate your voicemail.
If this continues please report this to our technical care team. They will also be able to activate this for you.
Katie 🙂
