21-04-2021 03:34 AM
filed a complain through the EE web portal as I am under the impression that my phone has been hacked. Firs I got a call from a withheld number from someone claiming to be from technical support, and he said it was "Impossible" to clone a sim car *google is full of ways to do this£ then I got an email from someone to be from EE asking me to call this number 0800 079 5327 I checked in google and this number does not seem to belong to EE, also this person said it was "Impossible" to clone a sim card, also my other complain that I spend too much data, he said was accurate, i would like to know if this number is real.
21-04-2021 06:16 AM
Your phone hasn't been hacked.
It's just scammers calling random numbers. It happens. If the number isn't withheld just block it
21-04-2021 07:54 AM
Hi @berlinsubbb69.
Welcome to the community.
If you'd like to talk to someone about your data usage, I'd recommend giving our Tech Care team a call directly so they can look into this for you.
They will also be able to check your account notes to make check if these calls were from EE advisors.
Jon
22-04-2021 12:23 AM
22-04-2021 08:34 AM
Do you mean the EE team called you back on a Mobile, @berlinsubbb69?
If so, what number did they leave to call? The number they called you from would likely just be an outbound number (probably 07973 100 194).
23-04-2021 12:51 PM
the number they used was 7953222222 the other suspicious thing was that when they sent me an email they didn`t use my acc nr. but my mobile nr. and they indicted me to call
0800 079 5327, so I want to make sure is a legitimate EE customer service number. My problem still persists, again my call records on ñline and the ones on my phone do not match and data consumption on the "My account site"· is more than double of what my phone shows.
23-04-2021 12:54 PM
The number ending with 22222 is the EE voicemail. That is not a dodgy number
23-04-2021 01:51 PM
Thanks, can someone from EE also confirm 0800 079 5327, is a valid number?
24-04-2021 08:02 AM
Hi @berlinsubbb69.
That number may be for a specific EE department, as the prefix at the beginning is similar to a normal EE number.
If you call the number on our get in touch page, you can be asked to be transferred to the relevant department.
Jon
30-04-2021 10:55 AM
also EE refuses to acknowledge the fact that my phone might have been hacked, what is the next instance where I can escalate my complaint, I keep seeing strange calls and texts in my bill. Is it the Ombudsman Services?
