Parental control
Kirsty210
Does anyone know of a way to restrict a child's phone usage through EE? Like after a certain time the phone doesn't work until the morning?
Many Thanks in Advance
Kirsty
1 ACCEPTED SOLUTION
You can manually disable mobile data via a toggle switch in the app, but they will still be able to use WiFi.
This is a function best employed via Android or Apple controls within the phone-OS itself. If your child is using Android, then Family Link can lock the phone entirely at pre-set times.
