esim
LouiseLa
I have a SIM only account and an iphone SE. I would like to convert to an esim so that I may use a physical sim for a French account. Is this possible?
@LouiseLa  You can request this via the my EE app.   Click the person icon top right the click settings and permissions and scroll down to activate sim/eSim. Then follow the onscreen instructions.
EssexBoyEE
As long as your iPhone is Unlocked and is Dual Sim compatible , in your case Sim + eSim rather than Sim or eSim then Yes to your question.
Easiest way to determine if your Device is Dual Sim compatible is it will have 2 different IMEI Numbers for each Sim Position.
I do! How do I go about changing to an esim?
Sent from my iPhone
