esim
1016
I have just got an iPad Pro cellular. I have a Sim only deal, how do I set up cellular service on my iPad please.
EssexBoyEE
If you have a Sim Card, just insert into the IPad then Restart your device and follow any Sim or Network Notifications on your Device, this should result in a Automatic Configuration to setup your IPad.
The above information assumes you are in a good Coverage Area and in the UK.
EssexBoyEE
Many thanks for your advice.
Sent from my iPhone
