eSim activation needs a PIN
dumontn123
I need an eSim activation but it needs a PIN sent to my phone number. I cannot receive the PIN without an active eSim. What a stupid system! Obviously my phone is not working. How do I get past this? Thanks
@dumontn123 wrote:
I need an eSim activation ... I cannot receive the PIN without an active eSim.
You need an active SIM to receive any text messages.
Are you changing from a physical to an electronic SIM?
Christopher_G
Hi @dumontn123
Welcome to the community.
Did you manage to get sorted? You can see all of the different scenarios for replacement eSIMs on this Downloading and using an eSIM help page. If you're still struggling, and you're near an EE Store, it may be worth popping in so they can help you get is set up.
